It is currently Sun Jun 22, 2025 9:23 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jan 18, 2006 10:26 pm
Simon, have a look at Kathy Matsushita's site she does flush mounted necks.
PostPosted: Wed Jan 18, 2006 10:58 pm
Thanks Colin, i'll go check there first and i might send an e-mail to Kathy on that, to know more about the technique because my first joint was a dovetail executed a la Elvis Presley, purdy twisted in the pelvis! YEAH!
Don't know what it is this mornin', but i feel like a king!
i'll keep you updated on her reply!
PostPosted: Thu Jan 19, 2006 1:00 am
I've done mostly flush mount. I drill a hole in the heel and and insert a 1/2 inch hardwood dowel. I use the birch or poplar that my local lumber yard carries. I make sure that the dowel is oriented so that the flat sawn side is facing the inserts.
As for inserts, I use the gray metal, slightly tapered, hex drive kind. I failed to sucessfully install the flat screwdrive driven brass inserts. They always stripped.
To screw them in, I take a straight hex wrench and chuck it into the drill press. I mount the neck, so that the inserts will go in at 90 degress to the pre-angled heel. This is the same setup I used to drill the holes for the inserts. WITH THE POWER OFF, I turn the drill press by hand and lower the wrench which sets the insert.
PostPosted: Thu Jan 19, 2006 3:48 am
SimonF, Here is a flush mount or butt joint neck from Mario Proulx's website. Not sure if this is what you are looking for, but it's interesting.
PostPosted: Fri Jan 20, 2006 1:42 pm
Flush mount? Any of you guys tryed that?
PostPosted: Sat Jan 21, 2006 8:04 am
I've used the flush mount neck on #'s 2,3 and 4. I like it. I seems there is a lot less "fiddling" than with a M & T. All of the guitars (2 dreds and an OM) sounded good. Besides, from some of the comments I read about Mario's guitars, it can't be a bad thing. With this joint and the secret being out about the PMTE, maybe someday I'll get there.
PostPosted: Sat Jan 21, 2006 10:14 am
I do too, like Jimmie I mean...Taylor used to do that, and I figure if it's good enough for them....    Plus, I made all the M/T joints I needed for a lifetime when I built furniture!
